Firefox 105.1 (19787) homepage cannot remove fisted sites
In this latest version, if you attempt to remove an item from the home page by a long press on the icon, when the menu pops up and you choose remove, nothing happens. Worked before I upgraded the version.
You can make that item a shortcut, visiting the page and then remove shortcut using the menu choice under the burger menu. But that is a pain.
I attached a photo to help with understanding. iPad os 15.6.1
Thanks, Wayne
Semua Balasan (3)
Sorry autocorrect issue. Visited sites not fisted.
I posted about the same problem and no help :(
This question has been locked because the original author has deleted their account. While you can no longer post new replies, the existing content remains available for reference.
